In need of an expert! I want to insert a button in toolbar which can use for applying my style that I customized.
I have also created a keyboard short cut for the same.
What to do with this.
Help me!
Insert button in toolbar which can use for applying style that customized
Hi James,
What program are you using toolbar?
It is java script? HTML?
First, you choose the series of buttons available on your program if its is JAVA, PHP etc. toolbar commonly displayed as a horizontal row and vertical row or column depending on you GUI settings.
Here's the quick solution for the first timer on how to insert/create a toolbar using your style using FrontPage:
1. Click Start.
2. Click Microsoft FrontPage, left click "File," "New" then "Blank Page".
3. Set "Design'' , "Split" or "Code"Â
The purpose of using Microsoft PowerPoint is to simply hardcode HTML especially on creating tables etc.
Thanks,
RavenÂ
