Insert image into Access from file
I have build a database of the students using MS Access, I need to insert the image also to the corresponding database. Is it possible to insert images into access from file, if so, how ?
Hello Deangellopeter,
Of course it is possible to insert images or even logos in to an access form file. To fulfill this purpose you first need to store the images somewhere. MS Access provides several methods to store images, which is
Thank you.
Rubi Sharlene
Follow this:
> Go to insert in the tool menu.
> Click on picture from there you can browse to the folder where your picture resides.
> Click on the picture and insert it into your form.
> In the properties box choose Embedded
> Then you have several sizing options under size mode that will allow you to size the picture the way you want it.
This will work with jpgs.
Or try using dbpix software to insert pictures in your database.
Thanking you
Frank Mary
Notifications
