Insert a picture into Microsoft word
Hi
1. Start Microsoft Word, and then open the text that you want.
2. Get on to place the placing point at the place in the document where you want to put in the picture. On the Insert menu, point to Picture, and then click From File.
3. Look through to the folder that hold the picture that you desire, click the picture file, and then click Insert.
4. Click the inserted picture, and then resize the picture, if essential. Pull the rotation handle to rotate the picture, if required.
5. Apply the tools on the Picture toolbar to modify the quality of the picture.
Thanks
This is a really easy task and there are few methods available for do this.
First method:
1. Open Microsoft windows.
2. Then click on the insert panel and click on the picture button.
3. Then browse your .jpg picture file from the open window and click on the insert button.
4. Picture will come to your word document page.
Second method:
- Open the Microsoft word and same time open your picture folder.
- Restore down your picture folder and drag your .jpg picture into the Microsoft word page.
Thank You,
John Major.
Dear,
