Inserting tables in SharePoint 2010 law office template
I need to make a table form in the sharepoint 2010 law office template to present the report to my senior management. Which option is used to insert table in sharepoint 2010?
Hi
To insert a table on page in sharepoint 2010:
Step 1. Go to "Page" tab and click on "Edit"
Step 2. Click on the Page where you want to add a table, Click on the "Insert" and then Click on the "Table"
Step 3. In the "Table" drop down menu. Click "Insert Table" then Enter No. of Rows and Columns and Click Ok And You can also select the No. of columns and rows in Grid.
Step 4. After adding table on a page you can use table tool to customize layout of your table.
Remeber to save all of your work.Â
