Hi Experts!
I am really impressed by the performance of the Instagram 1.1.0 in my smartphone. Is there anyone who can tell me if it is available for windows 8? In addition to that, extra information, tips and tricks and special features of the program is also very appreciable.
Instagram 1.1.0 compatibility with Windows 8
Windows 8 released preview is stable and has been thoughly tested but its not the finished product. so pc could crush,may be you could lose very important file.
You will also face encounter problem. software does not install properly.
Yeah you can use Instagram from windows 8.
All you have to do is manage to open it by your browser. For that there is a website
https://ink361.com/
There you can easily login throw your instagram. This website will help you to login to you instagram and do all the activities you can from you smartphones.
