Instagram built for Android does not fit for the HTC One X
JohnLMcManus 0 points N/APosted on - 05/23/2013
The camera is simply not compatible yet with HTC One X as extra camera support and camera features that jive well with the Android will be supplemented in the forthcoming updates.
Can I still sort this out? Please provide some help guys!
Camera Not supported
Unfortunately this camera is not yet support will be added in future updates
Hi John, regarding your concern, it seems that your HTC One X is one of the latest phones but it is a windows phone and not an android. I believe it is not yet compatible but here is one alternative solution, try searching for instagram for windows8 mobile and you will see some good results. Enjoy your phone!
The HTC One X is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on February 2012 and released on May 2012 measuring 134.4 x 69.9 x 8.9 millimeters and weighing 130 grams. It uses micro-SIM card. It has Super IPS LCD2 capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution.
HTC One X
It supports multi-touch protected with Corning Gorilla Glass with HTC Sense UI support. It ships with Android 4.0 Ice Cream Sandwich upgradable to Android 4.1.1 Jelly Bean powered by NVIDIA Tegra 3 chipset, 1.5 GHz Quad-Core processor, and ULP GeForce GPU. It doesn’t support microSD. It runs on 1 GB RAM with internal storage available in 16 GB and 32 GB capacities (26 GB available to user).
The primary camera supports 8 megapixels with AF featuring LED flash and can record video in 1080p at 24 fps with stereo sound rec. The secondary camera supports 1.3 megapixels and can record video in 720p.
It has 3.5-millimeter jack featuring Beats Audio and active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP and aptX support; GPS with A-GPS support; NFC; stereo FM radio with RDS support; and microUSB 2.0 with MHL TV-out. It has built-in accelerometer, gyro, proximity, and compass sensors. The pre-installed web browser supports HTML with Adobe Flash support.
It runs on non-removable Li-Po 1800 mAh battery and available in gray and white colors. If your phone ships with an Instagram app, you need to update it because it is in stock version. Download the latest app on the Google Play store: Instagram.
1....
