Instagram error during installation on iPad
Hello there,
I just installed Instagram on my iPad this is the nightmare that I have. I tried to install at least 15 times Instagram and nothing seems like to work. Can anyone help me please to fix this error ? What could be the problem ?
Thank you !
Instagram Error
Cancel Retry
Answered By 0 points N/A #179984
If you are facing this problem then it`s not a big issue. Simply go to your home screen in your device. Now go the settings and after this open the general and then open the reset settings. Then reset your all settings and restart your device now reconfigure all settings and network settings and after this go to the apple store and download Instagram again. You will get the success this time.
