Instagram in Phones such as Corby 2, Nokia Phones, etc.
Is it possible to have an Instagram in my Corby II? How can I install an app that is supported by my Corby II?
No, this is not possible. Instagram can only run with iOS devices. Instagram is an exciting way to share your photos and this was launched on 2010. It will let the users to take their photos, filter it and then share it on various social networking sites like Facebook, Twitter, Google+ and more. The main feature of Instagram is capability to keep the photos on a square shape that is similar to Kodak Instamatic and Polaroid pictures. Additionally, it has 4:3 aspect ratios that is commonly used the cameras on mobile devices.
On April, Instagram will be available on Android devices running Froyo 2.2 or higher. It can be shared through the iTunes App Store or through Google Play. For additional information, on April 12 Facebook purchased the company by outlaying $1-billion with stocks shares and in cash.
When installing Instagram on your device, you need to store it on the phone storage and then run the application by simply tapping on it.
Hello Joey
For you to be able to successfully run Instagram on your phone, it should have the following specifications:
The phone should support Android:
If your Corby II has got a camera and it can work with Android 2.2 or above , and it also supports OpenGL ES 2 then you can successfully run Instagram on it.
The phones that do not have OpenGL ES 2 cannot work with Instagram for they do not have the technology required to power Instagram's filters.
Also, if your phone's running Android older than 2.2. then it does not have the technology that is needed to power Instagram's filters.
Some Samsung Galaxy Y devices have been noted to have an issue that makes the images to look black on the filters screen as well as when they are uploaded
Apple iOS devices:
Instagram v2.0 and later versions can work well on iOS 4.2.1 and above. In case you do not have the mentioned version of iOS or later, then you will just have the old version of Instagram.
Carl
It is not possible. Instagram is only available for iPhone and Android users. But you can sure run this app on other Samsung devices such as those Galaxy versions that are running Android. And it is also not available for Nokia users. However, you can try other apps that is similar to Instagram wherein you can run on your Nokia, Android and BlackBerry phones. An example is the Molome. It is one great alternative for instagram app.
