Install activex for IP camera
Hi All,
I am using Internet Explorer 8 and id trying to view IP camera through it, which says to install ActiveX for IP camera, even after installing the same, I am unable to view the same.
Is that the problem with IE 8, Please help me by providing a solution.
Thanks, David Shawn
Answered By 5 points N/A #144474
Hello David
I must assume that you are encountering this error in Internet Explorer 8 on 64bit. This is the cause, because IE8 on 64bit does not support ActiveX controls.
Please reinstall Internet Explorer 8 but this time on 32bit.
Also, in order for you to enable the ActiveX, open Internet Explorer, go to Tools-> Internet Options. Under the Security tab click Custom Level. Locate ActiveX controls and check all the ActiveX options so that they are Enabled. Click OK and it will work
I have provided you with a link where you can download Internet Explorer 8 32bit version.
Download Link for Internet Explorer 8 for Windows XP and Windows Vista
Download Internet Explorer 8 for Windows 7
I hope you will find this information useful.
Randolph
