Install Adobe Acrobat Professional 11 On Your System
Hello everyone, I need to install the latest of the Acrobat professional. Kindly explain me the steps for the setup fix Adobe acrobat professional 11 on my system. I am currently working on Windows 7
Answered By 0 points N/A #307456
1. Get the software either online or offline from the store.
2. Explore the installer program.
3. Using the extractor program by Adobe, extract the downloaded files.
4. Enable the “Launch Adobe Acrobat XI” option.
5. Accept the User Account Control Box.
6. Select the language of your choice.
7. Click next button on the screen.
8. Provide the name of the required fields.
9. Select Next button.
10. Choose the type of installation.
11. Decide the path of the fixing.
12. Select Install button.
Answered By 590495 points N/A #309919
If you want to install Adobe Acrobat Professional, make sure your computer meets the requirements. Adobe Acrobat Pro supports Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit including Windows Server 2008 R2 (64-bit only), Windows Server 2012 (64-bit only), Windows Server 2012 R2 (64-bit only), and Windows Server 2016 (64-bit only).
It requires 1.5 GHz or faster processor, 1 GB RAM, 4.5 GB free space, and 1024 x 768 pixels screen resolution. The following web browsers are supported: Microsoft Internet Explorer 11, Google Chrome, and Mozilla Firefox ESR. Adobe Acrobat Pro is not free. The latest is Adobe Acrobat Pro DC and it costs $14.99 a month.
The application is now on subscription basis unlike before when you can still buy it as a standalone product. You can download the latest free trial from Adobe Acrobat Pro DC which works for seven days (7).
