Mili Nelson
Posted on - 02/06/2013
Techyv!
I'm having a problem using my flash player. I install adobe flash player as guest, and works definitely fine.
But it doesn't work when I don't log in as guest.
I need to get help with this.
Install adobe flash player as guest problem
Maybe you have downloaded and installed a Flash Player that is limited to one use only. You have to get a Flash Player with multi- use support. Try to download and install the latest version from the Adobe website, provided below:
https://get.adobe.com/flashplayer/
Hi, Mili Nelson,
I think you downloaded a flash player that is tailored for only one user. So, I will suggested that you uninstall it and follow the site below to download a more fine copy.
Go the https://filehippo.com/
You can also install the same copy to the other account.
Amos Marie
Hi Mili,
It appears that you installed flashplayer using a non admin account that is the reason why other guest or users cannot use it as well. If you want to make it available to all user's of the computer then install it again using an administrator login on your windows. It will be surely available for all accounts once its installed that way.
Hope this helps.
Kramer
Hi Mili Nelson,
When you installed the software you were logged in as guest.
So it works only for guest users and administrator of the system.
You need to login to the system as an administrator by using administrator user id and password.
If normal users login with different id and password (except guest and admin) then it won't work.
After logging as an admin you can make it available for any user as well from control panel settings.
Hope it solves your problem.
Thanks,
