Install adobe plug in windows 7 64-bit
I was using adobe flash 32-bit on my 64-bit windows. So I uninstalled it and then restart my computer. Then I downloaded the 64-bit version and tried to install adobe plug in windows 7 64-bit of my computer. When I tried to install the 64-bit version it stops saying an error that I have already a newer version on my computer.
Best Answer by Egerton Akeen
Answered By 0 points N/A #160453
Thanks for sharing the problem, I advise you to delete all the files related to 32 bit adobe flash bit you will find these files in program files (86). Now restart the PC hope everything will be ok.
And please install the 64 bit adobe flash after deleting all the 32 bit flash files.
Answered By 0 points N/A #160454
Hi Mas_009,
That is not really an error, it means that you don’t have to install the software you’d downloaded because your OS already have the newer version and it happens anytime especially if you set your windows to receive automatic update, unless otherwise you can’t open your Flash files.
