Install avast internet security for xp?
Hi Experts,
I installed avast internet security for XP.
After that I could not open certain software's because it had blocked them.
How to unblock them in avast internet security.
Onam Ophir
Answered By 0 points N/A #133147
Avast Internet Security covers a fully incorporated firewall which can be controlled in a straight line from the Avast user interface, where you can also locate the application rules prevailing the network and Internet communication for precise software applications.
The firewall will then follow these rules whenever a particular application tries to set up a link to the Internet or with one more networks. The subsequent steps in this regard are available on the Avast Internet Security website.
That will help you to know how to generate, regulate and arrange the firewall application rules in Avast Internet Security for the most ordinary applications that you may utilize.
I hope you understand it.
Answered By 590495 points N/A #133148
Avast Internet Security is a good antivirus and security application. If after the installation it blocked some of your programs or some of the programs installed on your computer, maybe the setting of the antivirus is too hard for the applications where they are being reported as unsafe to the system therefore blocking them from being executed. If this is the case, simply exclude the affected programs from the Avast real-time system protection.
All antivirus applications have this feature to allow a user to open a program that was blocked by the antivirus that is 100 percent clean. To do this, open your Avast Internet Security then go to Settings. In each tab, find an option that says something like “Files to exclude from real-time scan”. When you found it, add the executable file (.exe) of the affected application by clicking Add, select the executable file then click OK.
If you have multiple applications that don’t work, add all of them in the exclude option so that Avast will ignore them whenever the antivirus detected their launch.
