Install Control Centre For Brother Driver.
I was trying for options in the Brother Solutions Centre. I want that there must be a control centre for Brother Device. How can I install such software? What are the steps involved in it?
You can use the Brother Device for a lot of work like print, scan, photocopy, and FAX. The Control Centre software allows you to access to such task and helps you to manage them efficiently.It comes with an inbuilt driver for your Brother device.
• Visit the official Brother website for download control centre.
• Once you have downloaded it, install it using the Windows installation wizard.
Once installed, you can see the CC4 icon in the tray. Simply click on the icon to start the Control Centre. If there is no icon open the Start Menu and type Control Centre in the search box.
