To Install DOS 6.22 From CD In Easy-To-Understand Language
Hi. I am not very familiar with the computer-related software and hardware. I want to learn the steps to install DOS 6.22 from CD. Please reply ASAP. Thanks in advance.
Hi. The steps to install DOS 6.22 from CD require you to first download the VirtualBx. Next, download the DOS 6.22 after which the VirtualBox should be run and then the virtual machine should be set up by opening the VirtualBox and then clicking on new. Then, click on next and type a name for the virtual machine. Click on next and then create a new disk following which, click on next. Then, select a hard drive format and then click on next. Select a size for the drive on your computer and click on next. Then, create the machine.
After this, the virtual machine needs to be configured by clicking on the system page. Then, install the DOS by clicking on devices and then choosing a virtual floppy disk drive. Next, go to the location where the setup disks are downloaded and then click on the disk twice. Then, power off the machine and click on OK. Then, click on the virtual machine for which the DOS has been created twice. Follow the instructions which appear for the installation. Finally, the installation will complete. Hope we helped.
