Install Mass Effect in Linux
Can anyone tell me how to install Mass Effect 3 Game in Linux platform. I want to know whether It can be installed on CentOS or not. I have presently Ubuntu. But, I want to play this on CentOS.
First, Check whether your system meets the requirements of the Mass Effect.
Then install the Wine tool if it is not available.
Then install the PlayonLinux Tool using Wine which is easy way of installing.
Open the playonlinux app assuming that you have Mass effect 3 Cd /DVD. Launch the playonlinux it will show you to an interface to install button.
Click Install a non-listed program link available at the bottom of page. An installation wizard will appear click on next and then again next. Type the Game name when it asks then click on next.
Then select the wine tool from the list and click on next. This will install Wine 1.5.8 which is required for you to run the game once it is install you will see a prompt to provide the location of CD DVD of mass effect. Choose the binaries and click on install one it is done that it installation is completed.
Notifications
