Install Microsoft Office In Android Steps
Hello everyone, I always get e-mails which are in either in .doc format or .ppt format to which sometimes I need to edit it. Is there any other way to install Microsoft Office in Android? Kindly guide me through the steps.
Answered By 10 points N/A #302271
Yes, you can use Microsoft office on your android phone. Just follow the steps to install the app.
  1. Go to Google play store and select the right Office app.
  1. When you find the exact and suitable app of your use. Click it and choose download.
  1. Create or sign-in with your account into your mobile.
  1. Connect to your Dropbox or OneDrive.
  1. Now you are ready to work with your Microsoft Office.
Answered By 590495 points N/A #302804
If you frequently check your email messages using your Android phone and you often receive email messages with Office Word or Office PowerPoint attachment, you can install Microsoft Office Mobile on your Android device. The app requires Android 4.0 Ice Cream Sandwich and higher but is not recommended for Android 4.4 KitKat and higher.
Aside from installing the Office suite on your device, you can also install its applications individually. If you want to use Office Word on your device, download Microsoft Word. It requires Android 4.4 KitKat and higher. If you need Office Excel, download Microsoft Excel. It requires Android 4.4 KitKat and higher. If you need to open an Office PowerPoint attachment, download Microsoft PowerPoint.
