Hello, experts, I am having the setup CD of Microsoft visual basics 6.0. Kindly provide the guidelines and steps to install it on Windows7. Thank you.
Install Microsoft Visual Basics 6.0 In Windows7.
To install Visual Basic 6.0 on Windows7 follow steps:
- In C drive create a 0-Byte file in the msjava.dll directory.
- Right click on Setup.exe.
- Select run as Administrator.
- Click run program for the compatibility warnings.
- Until you don’t reach the Custom Setup, keep going.
- Choose next.
- Install MS-visual basic 6.0, ActiveX, Data Access, Graphics nothing else.
- Clicks continue and execute process finally.
If you have the setup CD for Microsoft Visual Basic 6, just insert it to your optical drive and wait for the disc to autoplay. This should bring up the setup screen for Microsoft Visual Basic. To install, just follow the instructions on the screen, accept the agreement, and accept default settings. Once you have it installed, the following important components can be installed:
- Code Advisor for Visual Basic 6.0 – supports Windows 98, Windows Millennium, Windows NT, Windows 2000, and Windows XP. This download does not support Windows Vista and higher.
- Visual Basic 6.0 to Visual Basic .NET Upgrade Assessment Tool – supports Windows 2000, Windows XP Professional, and Windows Server 2003. It requires Microsoft .NET Framework 1.1.
- Microsoft InteropForms Toolkit 2.1 – supports Windows XP, Windows Vista, Windows 7, Windows Server 2003, Windows Server 2008, and Windows Server 2008 R2. It requires Microsoft .NET Framework 2.0 and Microsoft Visual Studio (2005, 2008, or 2010).
- Visual Basic Power Packs
