Install mingw eclipse juno CDT
Have a situation adding the MinGW toolchain to Overshadowing CDT Juno (Construct id: 20120614-1722). Not beyond any doubt what I'm doing wrong, be that as it may it was faultlessly fine in Indigo. I want to install mingw eclipse juno.
Here are my steps for fixing the MinGW toolchain:
1. Within the Overshadowing IDE, from the menubar, select: Help | Fix Unique Programming.
2. Drop in the Wascana store URL. (Sorry, I was not permitted to put the connection here due to discussion runs)
3. Select the bundles that show up and accompany the on-screen prompts.
Best Answer by Sandra R Butters
Answered By 0 points N/A #135356
It is easy to install MinGW Eclipse Juno, just follow these steps:
Launch Eclipse
⇒ Help ⇒
Install New Software
⇒ In "Work with",
enter the CDT
update site http://download.eclipse.org/tools/cdt/releases/juno/ (for Eclipse Juno only) ⇒ Add ⇒ Enter a name (e.g., CDT 8.1.0) ⇒ You should select all the "CDT main features". You may select optional features.
Select the packages that appear and follow the on-screen prompts.
⇒ Finish.
Answered By 30 points N/A #135357
Hello Isabellartd,
To install MinGW eclipse Juno first make sure you have installed mingw and eclipse Java developer or eclipse packages.
If they have already installed then download CDT plug in and install it.
After that launch eclipse then go to Install new software from the Help option. Enter the CDT update site in the Work with option. You have to enter a name and select all the CDT main features.
At last hit the finish button to complete the process.
Hope this could be a help.
Good luck.
