Dibri Avery
60 points
Posted on - 09/28/2012
I just turned my PC into a movie player. It is not doing anything aside from playing videos and movies for me. I am proud of the high definition output of my monitor and I can say that it is the best ever. However, I have problem with my audio. As much as I want to create high quality audio output, I can’t do that unless I will install a pc surround sound audio level meter.
What are the hard wares I needed to make this possible?
Install a pc surround sound audio level meter
You need to upgrade your speakers to achieve a good quality output of your sounds. I can give you a software that can measure the quality of audio your computer outputs. The good quality of speakers that i suggest are Logitech and bose, you can also try sub-woofers on your pc so you can hear a movie like sounds.
Hi Dibri,
You need to replace your speaker as well as need to upgrade the drivers and software’s relating to the functionality of these speakers.
To see the compatible software’s for your speaker, please see the link below.
http://softwaretopic.informer.com/pc-surround-sound-audio-level-meter/
Basically surround sound speaker is a home theater speaker and you need your speaker on the lines of the same. However there are few speakers like Logitech 5:1 and other brands speaker that produces surround sound effect.
Hope this helps.
Thanks
Baker
Thank you for all the information, guys. Baker Mich, I am pleased with your nice solution and the link that you have provided is good and helpful. Upon visiting the site, I have found the most compatible software I needed for my speaker. After downloading the software, I can now create high quality audio output. Thanks again, my friends, for a really nice solution.
