Install Photoshop CSS on MacBook Pro 15 Retina
Hello, I have been trying hard to install Photoshop CSS on Macbook Pro 15 Retina running OS X Mavericks but with no success. I am getting a message everytime from Adobe saying tha installation was a failure. Can anyone please help me with this? I insert the disk and and a message asks if I would like to install? On yes, some processing is done and then the Adobe error message appears. What am I doing wrong? Please tell me the correct way to successfully complete installation of Photoshop CSS.
Answered By 0 points N/A #159277
Hi !
To solve your problem with installation of Photoshop CSS on your MacBook Pro 15 Retina running OS X Mavericks you will have to use the CC Cleaner Tool.
To do this you will have to follow some steps:
1) In the Finder go to Application/Utilities/Adobe Installer.
A1) Double-click the CC or CS product's Uninstaller
B1) Follow the onscreen instructions to complete the uninstallation.
C1) Restart your computer.
2) Download the Adobe Creative Cloud Cleaner Tool for Macintosh.
A2) Double-click Adobe Creative Cloud Cleaner Tool.dmg.
3) Double-click Adobe Creative Cloud Cleaner Tool and follow the instructions.
A3) Choose your language: Type e for English, and then press Return.
B3) Review the Adobe End-User License Agreement: Type y to accept or n to decline. Press Return.
C3) Select the version of the Creative Cloud or Creative Suite product you want to remove from the menu in the upper-right corner of the script window. Press Return.
D4) Select the product you want to clean up from the table, and then click Cleanup.
4) When you see the message "Adobe Creative Cloud Cleaner Tool completed successfully," click Quit.
A4) Verify that the Adobe CC Cleaner Tool completed.
B4) In a text editor, such as Text Edit, open /Users/[user name] Adobe Creative Cloud Cleaner Tool.log.
After all steps were followed run a normal installation.
Answered By 590495 points N/A #159278
If you are referring Photoshop CSS to CSS Hat then you probably need a supported Photoshop version. CSS HAT is a plug-in for Adobe Photoshop and it allows you to easily translate layer styles into CSS. To install CSS Hat, your computer needs to meet all the requirements. CSS Hat supports Windows XP, Windows Vista, Windows 7, Windows 8, Windows 8.1, and Windows 10.
For Mac, it supports OS X 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, and 10.11 El Capitan. The latest version of CSS Hat requires Photoshop CC 2014 and higher. If you are using an older version of Photoshop like Photoshop CS4, Photoshop CS5, and Photoshop CS6, you need to install the older version. You can download the older versions from the Source Profile in your account.
But you can only download them if you already have an account and already purchased them before. They offer 50 percent (50%) discount if you buy older versions.
