Install Printer For Your PC: Dell Printer Driver For Mac
Hi. I am using MAC, and I want to install Dell printer on it. What are the steps to Dell printer driver for Mac? It is urgent, so it will be great if you help. Thanks in advance!
Hi. The steps to install Dell printer driver for Mac OS X are-
1) First visit the website Support.Dell.com and download the printer driver
2) After the driver downloads, complete its installation by following the mentioned steps
3) Click on the icon of the Apple made on the left corner of the screen and from among the options, click on system preferences
4) Then, when the window opens up, click on print & fax
5) After the window opens, there will be an icon with a plus sign which needs to be clicked so that a printer application can be added
6) On the add printer window, click on IP indicated on the top
7) Set all options such as address, protocol, queue, name and location
8) Then go back to the Add window and select default indicated on the top so as to add the USB printer
9) Then amongst the printers displayed, click on the printer to be added
10) Click on add
11) To print, use the command command+P and then when the window gets displayed, select the number of pages and type of printer
12) Click on Print
Hope we helped
