As I attempted installing Microsoft SharePoint Server 2010 but it was not successful due to an error which says,
The install in progress conflicts with a previously installed Microsoft Office 2010 Server product.
I have tried basic troubleshooting and also uninstalled MS Office 2010 Server, but this still occurs.
Any solution?
Install in progress conflicts with a previously installed Microsoft Office
Dear user,
After doing some research via Google, I have figured out the solution for your problem. You see, there must be a problem with the registry for your Office Web Apps. You have to manually delete them, then reboot your computer and run CC Cleaner.
Hope this will help you.
Thank you.
Hello Ahart,
Please check the program files/ Microsoft Office servers.
I am sure this file is still there. that's why this problem creating.
Please delete this file and then install Microsoft Office 2010 server product.
Hope this will solve your problem.
For more detail information, please check this site.
Thank you and have a good day.
Easy way to fix this problem is that, you have to use “Windows installer CleanUp Utility” which shows you all the listed office Web Application by their name and you can remove by this tool all related Sharepoint applications.
After that procedure, restart your computer and run the Sharepoint 2010 installer package.
good Luck.
