Install Siri on iPhone 4 without Proxy
They said the Siri is good application for iPhone 4s. I want to Siri on my iPhone 4s. Do you think it would be possible to install it even without a proxy?
Hi there David.D.eckr,
If you have an iPhone 4S, you don’t need to install Siri, because Siri application is included in iPhone 4S, except on the older iDevice Generation.
You just need to activate Siri on your iPhone 4S. and also Siri need internet connection so you must be able to connect to internet to use Siri.
To activate Siri on your iPhone 4S, follow these instruction below :
1. Tap on Setting on your iPhone 4S homescreen
2. In setting screen, tap on General
3. In General screen, tap on Siri and turn the feature on.
To try Siri application hold down the HOME button for 3 or 4 seconds and the little Siri mic will pop up and beep, waiting for your question.
If you can't find Siri on General screen, maybe it's because Siri is turned off in RESTRICTIONS setting,
Tap on Setting > choose "General" then > choose "restrictions" > tap on "Enable Restriction" if restriction is still disable > Turn on Siri in restrictions list app > Siri will shown in General.
The Apple iPhone 4s is a 3G Smartphone operating on 2G and 3G network bands using GSM, CDMA, HSPA, and EVDO technologies. It was announced to the public and released on October 2011. It measures 115.2 x 58.6 x 9.3 millimeters and weighs 140 grams. It uses micro-SIM card with scratch-resistant glass back panel support.
It has LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 640 x 960 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass with oleophobic coating support. It runs on iOS 5 upgradable to iOS 9.3.3 powered by Apple A5 chipset, Dual Core 1.0 GHz Cortex-A9 processor, and PowerVR SGX543MP2 GPU. MicroSD is not supported.
It runs on 512 MB RAM with internal storage available in the following capacities: 8 GB, 16 GB, 32 GB, and 64 GB. The primary camera supports 8 megapixels with f/2.4, 35-millimeter, LED flash, and autofocus support. The primary camera features panorama, HDR photo, 1/3.2" sensor size, 1.4 µm pixel size, touch focus, geo-tagging, and face detection and can record video in 1080p at 30 fps.
The secondary camera supports VGA video recording in 480p at 30 fps with videocalling over Wi-Fi and 3G support. It has 3.5-millimeter jack featuring Active noise cancellation with dedicated mic support; Wi-Fi 802.11 b/g/n with hotspot support; Bluetooth 4.0 with A2DP and LE support; GPS with A-GPS and GLONASS support; and USB 2.0. Stereo FM radio is not supported. It has built-in accelerometer, compass, gyro, and proximity sensors.
The pre-installed Safari web browser supports HTML5. It doesn’t support Java. It runs on non-removable 5.3 Wh Li-Po 1432 mAh battery with standby time up to 200 hours both on 2G and 3G. Talk time is up to 14 hours on 2G and 8 hours on 3G. It is available in Black and White colors.
If you simply want to have Siri, you don’t need to look for it to install it. The Apple iPhone 4s Smartphone comes pre-installed with the Siri natural language virtual assistant app. To use or access Siri, press and hold on the Home button and ask her what you want.
