Install software ghost searching for blackberry
There is a problem during installation of ghost searching for blackberry. What is the detailed process for installing the ghost searching for blackberry?
Hi, Jair!
Not quite sure what application you are referring to. The closest application in mind would be the Ghost Radar. The application in which you have to install on your Blackberry that lets you know if there is a supernatural element in your surroundings. It tells you words pertaining where you are or the environment that you are in. Just go to your App world and download it from there. If this is not the application you are looking for, well, there is no "Ghost Searching" application out there.
Cheerio!
