Install SQL Server 2000 Home Edition
I am a new user of SQL server 2000 Home Edition. Please any one tell me procedure how can I install it in my computer?
Figure 1
Figure 2: Select Install Database Server Option
Figure 3
Figure 4
Figure 5
Figure 6
Figure 7
Figure 8
Figure 9
Figure 10
Figure 11
Figure 12
Figure 13
Figure 14
Hello!
SQL requires Windows Authentication and Microsoft has decided to change this or do away with it in Vista/Windows 7. But don't worry because SQL allows any users to log in without windows authentication. Install the program and do not select windows authentication to log in. Use a user name and password, it will work great on Vista and also it will work the same on Windows 7.
If I were you, you should start thinking about moving to SQL Server 2005 SP3 or SQL Server 2008 SP1 for compatibility under Windows 7. I hope I have solved your problem.
Thanks ….  🙂 D GOD BLESS!!!
