blair12
Posted on - 07/21/2011
Hi!
Is it possible to install two windows at a time?
Both will be installed in drive "C"?
Or I have to select different drives for both windows?
I am afraid will it make windows speed slow also?
What safety precaution I have to take if I want to install two windows at a time?
ayegired
5 points
Installing two Operating System on one partition
Installing two windows at a time in a same drive doesn't show any effect on the system performance. But the installations will take more time. This is the same case even if you are installing two windows in the different drives.
Example:
Installing two windows at a time means running two process at a time. So processor has to take ownership these two parallel jobs and pipelining process will come into act. So it take more time to install.
Thanks,
Anilkumar
Hi Blair12!
Well, before you consider installing a 2nd operating system. I would suggest you make a back-up of your important files just to be safe. At least if anything goes wrong, you always have a copy of your important files. Yes, it is possible to install 2 versions of windows in your computer but not on one  single drive, an operating system can only be installed in one drive or partition. Seeing that you posted this under Windows 98 Category, I'm quite not sure, I mean if you still have an installation disk for it, 1) You might be able to install it but getting updates could be difficult and 2) I don't think one would install Windows 98 these days, finding programs that would run on Windows 98 would also be difficult.
"Older version of the operating system should be installed first and then the newer version will be installed last on the other drive. Windows XP should be installed first to Drive C prior to installing windows vista/7 to Drive D:"
Check how many hard drives are in your computer. You can do this by opening My Computer. It will show a list of available drives your computer has.
It is not possible to format a drive in use, including the one containing windows. If you only have one drive available (Drive C) then you need to do a partition of your drive (Split or divide hard drive into several units for storage) and make another drive (Drive D) for you to be able to install a 2nd operating system.
 You can make multiple drives if you have enough space on your hard drive. Before you make a partition though, again make sure that you made a backup of your files because you will need to format (Doing format will erase all data within the drive) your drive and then do the partition after. After doing the partition, you now have 2 drives (you can have more drives if you want). Format the first one, this will be Drive C and format the second one which will be Drive D (Make sure you use the NTFS File System).
Once you’re done formatting your drives, you can proceed to install the older version of windows in Drive C and wait for the installation to complete. When you’re done, you can restart the computer and boot it up using the installation disk for your 2nd operating system. Install the 2nd operating system in Drive D, go through the steps and wait for the installation to complete. When completed, you can remove the installation disk from your disk/cd drive and restart the computer. You will then be prompted to choose which operating system you want to boot up. You now have 2 operating systems in your computer.
