RuthC
Posted on - 08/04/2011
The master of computer I want to ask, if Windows 7 ultimate SP1 can run stable and good on dual core 2140 1.6 GHz processor. I want to upgrade from windows XP SP3 to Windows 7, but fear it may not be compatible.
Please help the master.
Specifics of my computer:
Asus p5gc-mx
2 x ddr2 2.5 GB
Intel dualcore e2140
VGA card his ati radeon 4650 512MB
DVD combo Samsung
joesam
Install windows 7 ultimate SP1 on a dual core 1.6 GHz
You can install Windows 7 with the configuration you mentioned. As Windows 7 needs at least 1GB of RAM you have 2.5 GB, that's great and your processor will handle Windows 7 as it is a dual core after all and about your graphics it is also ok for Windows 7 to function properly. 512MB is not bad for the aero effects of the Windows 7.
Over all don't worry, you are good to go to upgrade your PC to Windows 7.
Hope its helpful for you cheers.
RuthC
Now I don't have to worry about compatibility.
Thanks Joesam
