Install Windows with help of USB
I want to reinstall Windows 8 on my system and my CD/DVD Rom is not working. Can I install this particular OS using a USB? If so, how can I do that?
Hi Alex,
Here's the step on how to install Windows 8 using USB
Plug in formatted USB key into the computer . Boot you computer from USB. This can be done in the BIOS. Normally you enter the BIOS with F1, Delete, Esc or any other key that highlighted on the screen. Press the key that say Boot and make sure that the USB has the priority. If ever that the computer is not booting from the USB just repeat the above procedure.
Hi Alex,
Yes, definitely. You can install your Windows 8 operating system on the USB and that process is called Bootable Windows USB. However, you need to undergo a series of process to be able to create it. The instruction is as follows:
1. Plug in the USB and ensure that the USB is clearly formatted
2. Download .ISO file on the Windows 8 Operating System
3. Download UltraISO and install it
4. Run the software
5. Navigate to the top and click “Bootable”
6. Click “Write Disk Image”
7. Ensure that you specified the right USB and select “Write Method”
8. Ensure that you have selected USB-HDD+
9. Click on “Write” and wait for a couple of minutes until in prompt
10. Click Finish
For more detailed process, kindly click the link below.
How to make Bootable Windows USB – This link will guide you through the Youtube video tutorial on how to make a Bootable Windows USB.
Ware
Hi Alex Baker,
By many techniques you can install this particulas OS using a USB. Besides these process you can do another way too. To get more way visit Techyv's this page.
