tamanna251
Posted on - 09/18/2011
Hi dear,
I need some help with this error. I want to install Windows Vista but every time I see this error message, when I install it. I tried many times to reinstall but the same error appears.
"Running: Install Windows Vista Enterprise SP1 Eng x86
Task Sequence: Install Windows Vista Enterprise SP1 Eng x86 has failed with the error code (0x80091007).For more information, please contact your system administrator or helpdesk operator.
The computer will automatically restart in 12:13 minutes"Â
Now I need your help. If you know how to solve this error then please share your help by answer. Please help me. ThanksÂ
ijpnet
5 points
Hi Tamanna251!
Before anything else, you need to save all of your important files or documents because reinstalling your operating system.
Windows Vista, would delete it and remove all of the peripherals such as printer from your computer. Turn your computer back on and boot from the disk.
You may follow this link which will guide you on how to properly reinstall your Windows Vista Enterprise SP1 Eng x86.
Take note during the step in setting up your hard drive. Instead of clicking on NEW option, you still need to click on FORMAT since your hard drive has existing files.
You need to totally wipe it out. After formatting, proceed in clicking on NEW and then follow the remaining steps.
