Installation of Adobe Software fails
I am trying to install a trial version of an Adobe software because I want to try the software before buying it.
But the installation fails with this error.
Help me.Â
Help me.Â
I have possible solutions for the problem that you are encountering please follow the methods that I will give you to solve the problem that you are having. 1. Try redownloading them maybe the corruption error occurred when you have successfully finish the download but they are incomplete try using a program for your downloads like Internet download manager for you to avoid this from happening again. 2. Maybe there are already been damage when it was uploaded check the comments on where you have download the files if it is good or not (some download sources has a comment box if the uploaded file is good or not)
