Hello Everyone,
I am trying to install Alcohol 52% 4521 on my computer but I got error message “Internal setup error. Contact support”. This message appears every time I attempt to install and when I press next button at the first dialog box. I have generic PC Athlon 1600+ and 512Mb Ram. Can somebody help me fix this problem?
Thank you in Advance.
Installation of Alcohol 52% 4521 error
Dear Josheph Adamm,
You were trying to install Alcohol, but you got an error message that is internal setup error. Here are some solutions for you. Follow the instructions below.
** For Alcohol users installing in windows 7 operating system and also use F-Secure they will have to turn off advanced process monitoring under deep guard. It will not allow a new install with it running. Also with newer versions of F-secure you may have to completely disable deep guard.
** If you have any problem or errors with Alcohol and use commodo firewall such as internal setup error during the installation also after installation then make sure that you only choose firewall in setting not the firewall with optimal or maximum protection.
** This types of problem can occurs when you using other antivirus also.
** Disable the firewall of your antivirus before installing Alcohol.
I hope your problem will be solved.
Thank you.
If you can’t install Alcohol 52% or installing it triggers an error, one possible reason is if you are using an old, unsupported operating system. Alcohol 52% supports all versions of Microsoft Windows like Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 except Windows 98 and Windows Millennium. Alcohol 52% is available in two versions: trial version and free version.
The free edition is intended for personal use only and cannot be used for business. If you want it for business, download the trial version instead. If you continue receiving the error, download Alcohol 52% again from the link above. If the problem continues, download Alcohol 120% instead.
