Installation of apps from Google chrome web store
Hi Katreena!
It’s very simple to download and add apps from “Google web store”. They are easy to download and convenient to use. I am giving you some steps with screenshots which may help you understand the simple process of installing the apps on your Google Chrome. The steps are as under:
Step 1: Go to your browser “Google Chrome” and sign in your Google account
Step 2: Search for “Google Chrome web store”
Step 3: Select the first link and GO
Step 4: Choose any desired application from web store page as shown in the picture
Step 5: Click “Add to Chrome”
Step 6: A pop-up window will appear and select “install”
Step 7: After installing has finished, click “Launch”
Step 8: Your app is ready to use
Thank you.
