luisantos
Posted on - 10/31/2011
Hi Experts ,
I’m installing a Clocking IT application but it’s not working in my Apache server. When I tried to configured but all I got are error messages. I don’t know why it can’t work; can you please help me on how to install it properly? Thanks !
lee hung
75 points
Installation of a Clocking IT application
Hallo Luisantos,
The problem here may be either with the clocking application that you are trying to install or the apache server. So the first thing that I will advise that you do is check and make sure that the apache service is running because you may be running the application when apache service is off hence causing the problem that you are receiving.
Another thing that you should do is make sure that you have the right clocking application, make sure that it is compatible to the operating system you are using and that it is not corrupt in some way. You may try getting another setup if the ones you are using refuse completely.
Hope this helps.
__
Regards
Lee Hung
