The installation is damaged error message
I have Adobe AIR installed and set on my Windows Vista machine. It was working fine on my machine before. One day there was this pop up which said there is a latest update, which I went ahead and installed.
But from the time I update it I am not able to view any files. I keep getting that some installation files are missing. I had a working application on my system.
Adobe AIR
This installation of this application is damaged. Try
re-installing or contacting the publisher for
assistance.
OK
I have tried reinstalling the software but I still get the same error message. I tried downloading some helper application, and when trying to view comes up with the same error message.
