Installation of Epson WorkForce DS510 Scanner in laptop
Marco P Hamm 130 points N/APosted on - 04/25/2015
Hello!
We just recently bought this scanner and we would like to know on how to properly install it with our laptop. We find it hard for the manual to be followed. Is there any automatic software that we can use to install this device? Can you give us a way to do this? Can you provide us also alternative ways on how to properly install this device? What are the other port options for this device? What are the printing options for this? Please help me. Thank you!
       The Epson workforce DS 510 document scanner is 26 ppm/52 ipm scan speeds, Scans both sides just one pass, It directly popular cloud services and it scan Sharepoint, Evernote and google drive PC and Mac compatible.
       It scans to searchable PDF's and it scan and edit documents, Saved documents are PDF files, OCR software included, It saves on office space so that the compact scanner fits in all environments.
       Easily scan of document 50 page automatic document feeder and get the reliable performance duty cycle up to 2000 sheets per day, double detection prevents paper jam and finally enjoy one touch scanning 30 user definable scan jobs like to scan to cloud and scan to pdf.
If you have an Epson WorkForce DS-510 scanner, like any other scanner, you have to install the driver first before you can use it to scan documents. It will not function as you want it to be if no driver is installed because there is no way for the system to identify and access the device.
If you bought the product brand new, there should be a CD included in the package containing the drivers. Just insert the CD in your optical driver and browse the contents. Locate the software for the scanner and double-click it to install. On the other hand, if no CD is included in the package or you no longer have it, you can always download it from the manufacturer’s website.
Go to Epson WorkForce DS-510. The page should detect your operating system automatically. If you see a different operating system, click to change then select your correct operating system. The Epson WorkForce DS-510 document scanner supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Server 2003, Windows Server 2008, Windows Server 2012, and Windows Server 2016.
Download and install all available drivers and software for your device. Make sure the scanner is connected to your computer via the USB cable when installing.
1....
