Installation error 1005 for bullzip PDF printer
I have been trying to install the Bullzip PDF Printer on my system but I am facing some difficulties in printing the PDFs. When I start the conversion process, I am met with the following error on my screen:
The statement of the error is:  An error occurred.  Error 1005: Unable to locate the Ghostscript installation.  Source: GUl  Internal hint: Run converter to create PDF files
An error occurred.
Source: GUl
Has anyone else also encountered such a problem? If you know the solution, please do let me know.
Waiting for your comments and suggestions
Araceliariana
Best Answer by Smith Thompson
Answered By 0 points N/A #141987
First, I suggest that you reboot your system then run again the installation program.
If you still get Error 1005, just extract ghostscript lite from bullzip or http://www.bullzip.com/download/gsl/gslite.exe. The installer has gslite.exe name format. After the download, install it on your computer.
Hope this works and so you can run Bullzip PDF printer. Bullzip works with several programs such as AutoCAD, Firefox, Word and any Microsoft Windows applications.
Bullzip PDF printer
Answered By 10 points N/A #141988
The program constrains the basic programming errors.
This happens when you have not the full version of program or some files are missing from the program.
Reinstall the program can solve the problem try to run in safe mode and then try to execute the program.
If the problem remains reinstall the program if it also does not work then download the program again to make it effective and check specifications.
Smith Thompson
Answered By 590495 points N/A #305215
I think you forgot to check the system requirements of the program before you install it. Before installing any application, you need to make sure your computer meets the requirements. Also, you need to install first all the prerequisite components before installing the actual software. The error is obvious: you don’t have the Ghostscript installed on your computer.
Before installing Bullzip PDF Printer, you need to install first the following components:
  • GPL Ghostscript 9.10 or later – you can download it directly from Ghostscript Distribution.
  • Xpdf – you can download this component directly from Xpdf Distribution. This component is optional. You can use Bullzip PDF Printer with or without this component.
  • PDF Power Tool – download PDF Power Tool. This component is also optional.
Once all components have been installed, start Bullzip PDF Printer again. This should fix the problem. Bullzip PDF Printer supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. For servers, it supports Windows Server 2003, Windows Server 2008, Windows Server 2012, and Windows Server 2016. You can download the latest from Bullzip Free PDF Printer.
