Installation error 12052 on Nokia 5800 XpressMusic
10 points
Posted on - 04/17/2012
I tried to update Nokia 5800 XpressMusic Software to a beta version (3.3.49). It almost finished but instead gave out an error code 12052. What do you suggest I do? Is the newer beta version better? Appreciate your help very much.
Update Nokia 5800 XpressMusic software
Something’s gone wrong
There was problem with Nokia Suite. Please restart the program and try again. If the problem doesn’t go away, uninstall Nokia Suite and download the latest version of the application from http://www.nokia.com/in-en/support/product/nokia-suite
Error code: 12052Â
