When I ran vSphere client 4.0 installation on a Windows 7 platform, a terrific error occurred. I got the following error message, saying,
“The Microsoft Visual J# 2.0 Second Edition installer returned error code ‘4113’ ".
Do you know how to overcome the problem? I am tired with several attempts.
Please help.
Installation error code ‘4113’ – Microsoft Visual J#2.0 2nd Edition
Hi Halleleilani2,
To fix this, you need to uninstall first any existing copies of your Microsoft Visual J# 2.0 Redistributive Package. Just go to Control Panel then Programs and Programs and Features. When you are finish, now you can able to install VMWare client.
Hope it will help you.
You have not clearly mention Windows 7 32bit or 64bit. I use windows 7 32bit and install click VMware-viclient-all-4.1.0 successfully.
Follow below instructions:
First uninstall Microsoft Visual J# 2.0 Redistributable Package. Then Restart your then Right click VMware-viclient-all-4.1.0-258902 setup file Select Properties then click unblock button in General tab. Then press ok
(See image attachment)
That's all now you can install VMware-viclient-all-4.1
