Installation error on Jacket 2.0
In these days I installed a fresh version of jacke 2.0 however I am not able to install this because of an issue. I received the error message as you can see below while I run “go active”.
>> Activate
Welcome to the Jacket: The GPU Engine for MATLAB!
Verifying Installation ….
Is Jacket gpu_entry.mex file found? …. OK
Is the driver version correct? …. ??? Invalid MEX-file 'C:Program FilesAccelerEyesJacketenginegetcudrvver.mexw64': The
Specified module could not be found.
Error in ==> C:Program FilesAccelerEyesJacketenginegactivate.p>gactivate at 27
Hope for assistance
Answered By 30 points N/A #150541
Hello there Jay,
What drivers do you have installed on your system?
It looks like a driver conflict that would be resolved by using the alternate or upgraded drivers.
Also, there is a known bug waiting for the fix to come. In case you are running 32 bit Matlab on the 64 bit computer, there is a compatibility problem. While waiting for fix to be officially out, there is a simple workaround: visit the Accelereyes website, download the 2.0 zip file, unpack it and manually overwrite the existing files in the jacket folder.
