Installation Error on Max 4.7.7
Hi. I am running Windows 7 64-Bit. I tried to install a software using MAX 4.7.7. But I am having an error as shown below:
Measurement & Automation Explorer
SR-03-000-CPU (10.5.2.123):
The selected system does not support this function.
OK
I also have NI Developer Suite 2011 which I was able to uninstalled and re-installed back but the error still exists. And also, I can be able to install software in other PC. How can I fix this error? Please help.
Answered By 5 points N/A #166364
It seems like the application that you are running is corrupt. It also seems that what you are running is not executable application as we can see from the error message "The selected system does not support this function". Or it could be due to compatibility issues. So what I will recommend that you do is the following:
  • Go to the internet and search for another MAX application. I will recommend that you get it from sites like cnet downloads and majorgeeks which are trusted sites for genuine applications.
  • Before you even search the applications, you will have checked the system specifications so that the application you download meets those system specifications.
  • Download it and then try installing and see what happens.
-Experttechyv
