Hi experts,
I am receiving an installation error message when I am trying to set up Windows 2010 Beta.
Microsoft Office Home and Business 2010 (Beta) There was a problem setting up Microsoft Office Home and Business 2010 (Beta): There was a problem setting up Microsoft Office. Try running Setup again. If the problem continues, contact Microsoft Product Support.
I use Vista Ultimate Service Pack 2 installed together with Office 2007. However, the error message has no error code as well as just informs me to attempt again or to contact support. Then I have rebooted my system again, attempted to load the file from both webpage and desktop.
But still I find the same error message.
2010 (Beta):
                                         OK
I am using:
Dell 1525
2.0 GHz
32-bit Operating System
3 GB RAM
Please help.
Installation error message with Windows 2010 Beta
I suggest that you have to uninstall it now because it is having an error. Download another Microsoft Office 2010 Beta. Try another download and install it in your computer. This is the best option I can give you. Try this link below:
Just select from the two links. I hope this will help you a lot.
