Installation of Exchange 2007 32 bit version
Hi everyone ,
 I just, heard that it is necessary to install Exchange 2007, I need the 64 bit version of Windows Server 2003. Is it True?? Let me know, if there is a 32-bit version.
Thank you
Hi everyone ,
Thank you
Hello Evelozano,
 There should be a 32 bit version of the ms exchange 2007 otherwise it will a very disadvantage for the people who use the 32 bit version of windows. Since the versions are so strict when it comes to which versions of applications that you can execute of them, either they are 32 bit or 64 bit, then there should be ms exchange that should run on the 32 bit version of windows.
If you do not get one then it will mean that you switch your windows operating system to the 64 bit version of exchange. But you can still try out other mail servers like outlook in case you do not want to switch to the 64 bit windows version.
Hope this helps.
__
Regards
Lee Hung
