CarolH
Posted on - 10/19/2011
Hello to TechyV!
I am installing Photoshop from a CD lent to me by a friend. He said it works fine on his pc.
I got this error, however, when I tried to run the .exe file on mine. Is the CD corrupted or is there something incompatible with my desktop? What can I do to fix it?
Thank you, I'm much obligated!
Adobe Photoshop CS4 install…
Adobe Photoshop CS4 installation failed with an error Code: 3221225478
Installation Failed Adobe Photoshop CS4
Have you tried to install it not using a cd? Try to copy the installer from the cd and then paste in to you local drive and then try to install it again. I have a problem also regarding installation of Adobe and I tried to apply that solution and it works. But if it’s still do not work. Maybe the file from the C.D corrupt or are not complete installer. To make sure that the installer is working or really not working; try to install it to other computer. If it works, look for some program of your system that could possibly the reason while the set up is not running well, such as anti virus or security programs. Hope it will help.
