dee dawson
20 points
Posted on - 09/09/2012
I tried to installed file manager to split some file with the help of iPhones, but the installation failed due to anonymous error. How the installation be successful of split view file manager in iPhones?
Installation failed of split view file manager in iPhone
If you are using i-FunBox®’s File Manager for iPhone, iPad, and iPod Touch then maybe you are using an older version of this product. Older version may tend to have a much lower compatibility level to newer versions of the device. With i-FunBox®’s File Manager, you can manage files on your iPhone and or iPad in a way just like Windows File Explorer but more robust and friendly.
It easily transmits files and folders to your computer with the optimized file transfer and browsing. iOS 5.1 is now fully supported. You can use your iPhone as a USB Portable Disk for general files. Exploit the large flash memory on iPhone or iPad with transmission speed beyond 5 MB/s on iPhone and 15 MB/s on iPad. If you wish to download the latest version, you may visit i-FunBox®’s File Manager for iPhone, iPad, and iPod Touch.
