Jaila Eye
Posted on - 04/16/2012
I was having trouble in installing Code Composer Studio in one of the PCs in the office. I waited for a several hours and then tried to reinstall but I got the same error message. I checked the server as recommended by the message and it seemed correct.
Anyway, please help me resolve the error. The software is needed ASAP. Thanks in advance.
Welcome to Code Composer Studio
An error occurred attempting to acquire a license for this product.
Reason:
License server machine is down or not responding.
See the system administrator about starting the license server system, or make sure you’re referring to the right host (see LM_LICENSE_FILE).
Feature: CSS_DEBUGGER
Hostname: 134.91.65.50
License path: [email protected];C:Program FilesTexas Instruments ccsv4DebugServerlicense*.lic;C:ProgrammeTexas Insturmentsccsv4DebugServerlicense*.lic;C:tilicense;
FLEXNet Licensing error:-96, 491
Installation failed when installing Code Composer Studio
May be there's some problem with your CCS (code compose studios) downloads. Sometime problems can ttok place on your installing CCS. Probably main problem have happened when you downloaded the software. So follow the given below instructions.
Step 1. Remove/delete the software (CCS) from your PC.
Step 2. Re0download CCS. Remind that you have to download latest versions of the software (older versions you may found, but they have may creating problem on your pc for the PC's requirement) and make sure the download process. Because there no chances to occurred any downloading error, that you missed (to look after) last time. Download the full installer.
Step 3. Save the installer zip and unzipped it in a new folder.
Step 4. Go to the folder where you unzipped the installer.
Step 4. Now you have to run the installer to a directory.
Keep it in mind that- open new folder that is free from any accented or special characters, in the 4th step also remind this.
Hope now you can't face any error problem to install CCS.
