LANDesk agent is not being installed on my computer. I have seen an error message while the installation process was running.
Please help
Error
An error occurred installing the agent. Please check the xtrace log for further details
c:Document~1Admin~1Temp\wsdg32.xlg
Installation fails of LANDesk agent
Where there is a problem, there is a solution. So, of course it has a solution. Just do the following and get rid of the problem:
1. Download Microsoft's WMIDiag utility from the link:Â http://www.microsoft.com/en-us/download/details.aspx?id=7684
2. Execute the utility on your machine.
3. Now try to install the LANDesk Agent once again.
Problem is gone. Am I right?
Thanks for asking.
Hathy
It might be a good idea to visit this site: https://www.microsoft.com/en-us/download/details.aspx?id=7684. You can easily find help there. They have installation instructions and also the information on the patch. Visit it right away to resolve your query and to find many changes and improvements for your system. I hope you are doing well and have good day.
