I have been using coreldraw since long time. Presently I got a laptop which operating software version is Mac, for that reason I am thinking that I will install coreldraw es compatible con mac on this laptop. Yesterday one of colleague informed me that before install check the compatibility issue. Can somebody experienced on Mac advice me please?
Installation issue coreldraw es compatible con mapc in my laptop.
Hi David,
The compatibility issue that your colleague is referring to is the software's system requirement. All software's have its own requirement which is important to consider before installing it.
If you have installed an incompatible software in your laptop, the consequence of it is that it will not work and it's useless to keep it since it will just eat some space in your hard drive. So you will need to remove or uninstall it.
Since you are using a MAC laptop, you will need to purchase the software and select the product which is compatible with the MAC operating system. To be safe, analyze first the requirement of the software you are going to buy.
This is the sample CorelDraw specifications which give further information about the software's requirement. If the operating system is not made for MAC OS then it's not the one for you.
If you do not know the version of your MAC Operating System, you can check it in the About Menu from the Apple icon located in the upper left corner of your laptop's screen.
I hope this information have helped you.
For CorelDraw, unfortunately, there is no port for Macintosh. CorelDraw is available on Microsoft Windows only. If you badly needed to install and use CorelDraw on your Mac, one workaround is to use Parallels. This will allow you to install Windows applications on Macintosh computer. Unfortunately, Parallels is not free software but you can download their free trial.
Head down to the Parallels Desktop page and download their free trial. The trial version can be installed and used for free for fourteen (14) days with full features. Parallels Desktop is a virtual machine. It allows you to create a virtual machine where you can install your Windows operating system. After that, you can then install the Windows application you want to use.
For the pricing, visit the Buy Parallels Desktop page for details. A new license costs $79.99 and $49.99 for upgrade.
