The installation of the LSP failed
Guys, the installation of mine Avira Free Antivirus came to an abrupt end because the installation of the LSP failed. AntiVir MailGuard and AntiVir WebGuard therefore cannot be installed.
We recommend that you repair the LSP stack and then reinstall AntiVir MailGuard and AntiVir WebGuard via the user-defined installation. According to an error dialog.
I don’t know what LSP stands for but isn’t that already a part of Avira’s installation file? If it isn’t, where can I get a copy?
Setup of Avira AntiVir Personal – Free Antivirus
The installation of the LSP failed. AntiVir MailGuard and AntiVir WebGuard therefore cannot be installed. We recommend that you repair the LSP stack and then reinstall AntiVir MailGuard and AntiVir WebGuard via the user-defined installation.
OK
