Installation MS Office 2010, I get the error message
Hi all,
When I try to install MS Office 2010, I get the following error message. Why this message occurs?
Please give me a solution to solve it.
Thanks a lot.
Microsoft Word
The function you are attempting to run contains macros or content that requires macro language support. When this software was installed, you (or your administrator) chose not to install support for macros or controls.
Hide Help Open in Help Window
This error usually occurs because of macro security settings. If you know that the macro comes from a source that you trust, you can change your macro security settings to allow you to enable the macro
If the file opens in Protected views, click Enable Editing, and then click Enable content. Editing functions are restored and the active content, including macros will run. This file is now trusted: security prompts will no longer appear unless the file is opened on another computer.
OK Help
